beachbuggy Posted December 5, 2008 Share Posted December 5, 2008 Hi i want to swap over to megajolt for the ignition on my v8, i am familiar with which parts i need and have a edis 8 unit in the bag but there are 2 issues you may be able to help me with ! being a little lazy maybe! but im after a good map to install in the megajolt, im figuring there is one out there which runs a peach !! that someone is real proud of, i dont mind a small donation to the beer fund so i dont have to go through the steep learning curve, the second thing is where to get a megajolt kit from in the uk thanks Quote Link to comment Share on other sites More sharing options...
TIMBERWOLF Posted December 8, 2008 Share Posted December 8, 2008 Hi i want to swap over to megajolt for the ignition on my v8, i am familiar with which parts i need and have a edis 8 unit in the bag but there are 2 issues you may be able to help me with ! being a little lazy maybe! but im after a good map to install in the megajolt, im figuring there is one out there which runs a peach !! that someone is real proud of, i dont mind a small donation to the beer fund so i dont have to go through the steep learning curve, the second thing is where to get a megajolt kit from in the uk thanks Maybe this could help? http://www.megasquirtmaps.com/board/index.php?showforum=58 Interested in your handle and the v8 idea. Currently trying to fit a rover v8 onto a vw gearbox to go into my.......beachbuggy! (kind of a crossover beachbuggy cum rail) look at www.bajaclub.co.uk and the Timberwolf build thread in readers rides: http://www.bajaclub.co.uk/phpBB3/viewtopic...f=12&t=4062 Quote Link to comment Share on other sites More sharing options...
Tomcat Nev Posted December 9, 2008 Share Posted December 9, 2008 If you email me direct i can let you have a map or 2 that worked for me - depending on your engine spec of course. Nev Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted December 9, 2008 Share Posted December 9, 2008 RangeyRover is selling MJ's so I'd say he's your man for that. For a map, there have been loads posted in the MegaSquirt thread(s), check Nige's thread in the Tools'n'Fab forum for starters. You may have to type it in manually as I don't know if the MJ software will load the file direct. Quote Link to comment Share on other sites More sharing options...
