western Posted January 9, 2009 Share Posted January 9, 2009 Just love mine, one of the best bits of kit my 110 has been fitted with, no more jammed up expander & when set up correctly you can feel the caliper spring releasing. easy to fit too Quote Link to comment Share on other sites More sharing options...
fender1234 Posted January 13, 2009 Author Share Posted January 13, 2009 Just love mine, one of the best bits of kit my 110 has been fitted with, no more jammed up expander & when set up correctly you can feel the caliper spring releasing. easy to fit too managed to fix the old handbrake so no x brake for me yet. Ive fitted m12 bolts for the new steering stops but where they have to be adjusted so far out for the big tyres it means the side of the bolt is what hits the axle instead of the bolt head, has anyone else experianced this and is it a problem ie strength, bolt flexing/bending ? cheers Quote Link to comment Share on other sites More sharing options...
western Posted January 13, 2009 Share Posted January 13, 2009 you could put a tube sleeve over the exposed thread, so it's tight when the bolt is correctly set. Quote Link to comment Share on other sites More sharing options...
landmannnn Posted January 13, 2009 Share Posted January 13, 2009 I fancy it but i cant decide is it really worth spending £200 on a handbrake? Depends where you look at it from. £200 to save the hassle of cleaning it out regularly - maybe £200 to save leaving in gear when parking - not really £200 to keep it from rolling away into trees/ditches/etc - yes! Quote Link to comment Share on other sites More sharing options...
