Project Green Oval Posted December 13, 2008 Share Posted December 13, 2008 Hi does anyone know the size of the rear sub? in a disco1 and how they are powered where is the amp? has anyone replaced them with something better what is good to use? Any help would be great David Quote Link to comment Share on other sites More sharing options...
alex milton-haynes Posted December 14, 2008 Share Posted December 14, 2008 got to be pretty small to fit in there, id say about 6"? Quote Link to comment Share on other sites More sharing options...
ghost111 Posted December 15, 2008 Share Posted December 15, 2008 2 subs... around 5.5 inches mounted in custom enclosure, with an amp mounted behind them http://www.crutchfield.com/p_2068C65VT4/Ki...654.html?tp=111 you can make them fit... Quote Link to comment Share on other sites More sharing options...
teabag Posted December 15, 2008 Share Posted December 15, 2008 Hi does anyone know the size of the rear sub? in a disco1 and how they are powered where is the amp?has anyone replaced them with something better what is good to use? Any help would be great David A 10" sub loudspeaker in a box in the boot with an 200watt amp under the passenger seat and the signal picked up from the door sub amp is 100% better. Using a switch to switch back to the door sub if the sub in a box is removed for extra space. Quote Link to comment Share on other sites More sharing options...
