pritch1 Posted February 4, 2006 Share Posted February 4, 2006 i am planning on sitting a 3 bolt power steering box to my 200 tdi 90, which is at the moment not power assisted and i am struggeling finding the right pipes. i have these part numbers NTC6863 NTC8193 NTC8861 Does anyone know if these are correct? thanks matt Quote Link to comment Share on other sites More sharing options...
western Posted February 4, 2006 Share Posted February 4, 2006 Gimme your 90's VIN & I can tell which pipes you need Quote Link to comment Share on other sites More sharing options...
pritch1 Posted February 7, 2006 Author Share Posted February 7, 2006 the vin is salldvah7aa228262 it is an early 90 with a 2000 tdi engine and i believe the 3 bolt box is out of a 110 thanks Quote Link to comment Share on other sites More sharing options...
western Posted February 7, 2006 Share Posted February 7, 2006 Using your VIN my EPC tells me these pipes upto VIN AA244022 [yours AA228262] nrc8286 reservior to pump nrc8290 pump to steering box nrc7987 steering box to reservior check these pipes will fit the 200Tdi pump, I'm sure the 200Tdi pump is etc9070. 200Tdi pipes ntc8193 steering box to pump ntc6836 or ntc8192 reservior to pump [depending on res being the black metal or brown plastic ZF type] ntc7982 res to steering box [metal res] ntc8861 [plastic res] hope that helps probably confused you even more Quote Link to comment Share on other sites More sharing options...
pritch1 Posted February 7, 2006 Author Share Posted February 7, 2006 yea confused me a little does any one know if they used the 3 bolt power steering on the 200 tdi surley i would just be able to use them pipes, thanks for looking up the part numbers western great help just need sort which ones Quote Link to comment Share on other sites More sharing options...
western Posted February 7, 2006 Share Posted February 7, 2006 EPC doesn't give any VIN ranges for the fit of 3 bolt boxes, it just says this STC8382---RHD - power steering - exchange - heavyweight - Adwest checked Microcat as well just says the same, no VIN details shown my paper parts cat [Defender 1987 on includes 200/300Tdi engines] doesn't show a 3 bolt box manual or power, only shows 4 & 6 bolt boxes. hope that helps a bit further. Quote Link to comment Share on other sites More sharing options...
