MogLite Posted February 6, 2006 Share Posted February 6, 2006 I need some 3/8 UNC exhaust manifold studs I'm using 101 manifolds, but they use a different mounting arrangement, to what I'm planing. Are 3/8UNC studs used on an other Landies ? Part numbers ? Quote Link to comment Share on other sites More sharing options...
Les Henson Posted February 6, 2006 Share Posted February 6, 2006 Do they have to be studs? I think I have a box of bolts that size. Or Roger Barton is your man. Les. Quote Link to comment Share on other sites More sharing options...
MogLite Posted February 6, 2006 Author Share Posted February 6, 2006 Do they have to be studs? I think I have a box of bolts that size.Or Roger Barton is your man. Les. Studs I thought would be better, I was going to use V8 head->exhaust manifold bolts. Quote Link to comment Share on other sites More sharing options...
02GF74 Posted February 6, 2006 Share Posted February 6, 2006 Studs I thought would be better, I was going to use V8 head->exhaust manifold bolts. 3/8 unc sounds like the right size - need to check this at home tho' There has been discussion about stud vs bolt and am I not convinced that studs are better. All production cars with rover v8 from the big makers had bolts fitted and I am not aware of there being problems. One thing to bear in mind that if you don't have a lot of space around the manifold (like me, v8 in lwt), you will not get them on with studs; I struggled getting the bolts in, one was next to impossible until an inspired moment to use a short length of rubber hose to hold the bolt then turn it using one finger from each hand. Quote Link to comment Share on other sites More sharing options...
