Matthew Posted December 25, 2008 Share Posted December 25, 2008 Anyone know off hand where the electrical earthing points are on a 200TDi...just want to make sure I don't miss any of them! Thanks, Matt Quote Link to comment Share on other sites More sharing options...
western Posted December 25, 2008 Share Posted December 25, 2008 main earths [points are 1 engine to chassis at alternator/PAS bracket to left chassis part of left engine mounting 2 battery negative to main gearbox/transfer box joint 3 bulkhead between fuel filter & brake servo [bunch of black wires attached by a screw to bulkhead] 4 various others behing dash 5 front lights -- behind each set of lights to vertical panel of inner wing 6 behind each rear light cover panel in each rear corner. that should keep you busy hth Quote Link to comment Share on other sites More sharing options...
Matthew Posted December 26, 2008 Author Share Posted December 26, 2008 main earths [points are 1 engine to chassis at alternator/PAS bracket to left chassis part of left engine mounting 2 battery negative to main gearbox/transfer box joint 3 bulkhead between fuel filter & brake servo [bunch of black wires attached by a screw to bulkhead] 4 various others behing dash 5 front lights -- behind each set of lights to vertical panel of inner wing 6 behind each rear light cover panel in each rear corner. that should keep you busy hth Thanks once again western! Found a good few of those yesterday..but plenty more to go!! matt Quote Link to comment Share on other sites More sharing options...
western Posted December 26, 2008 Share Posted December 26, 2008 happy to help, how did you get away from the festivities to work on the LR ? Quote Link to comment Share on other sites More sharing options...
Matthew Posted December 26, 2008 Author Share Posted December 26, 2008 Its been off the road for a couple of weeks now, keep fixing one fault and finding three more! Christmas was pretty quite for me this year so rather than falling asleep in front of the tv all afternoon I got to work....and today its running perfectly B) Thanks again, matt Quote Link to comment Share on other sites More sharing options...
western Posted December 26, 2008 Share Posted December 26, 2008 no wasted time then, good to read it's running well. Quote Link to comment Share on other sites More sharing options...
