T1G UP Posted February 12, 2006 Share Posted February 12, 2006 I've been offered a stripped down 200 tdi motor from a mate that started but didn't finish.whilst it's aparts what do i look for in terms of wear? what bits could be upgraded for more power and will an autobox fit this engine,if so which one? Quote Link to comment Share on other sites More sharing options...
western Posted February 12, 2006 Share Posted February 12, 2006 Examine for wear these ---- all bearings-- crankshaft, camshaft, conrods both ends & cylinder bores crank & cam bearing surfaces oil pump rockers /rockershaft & valve tops/caps turbocharger 200's were used in Discovery with auto box so you could use the rlevant parts from that source. Quote Link to comment Share on other sites More sharing options...
T1G UP Posted February 12, 2006 Author Share Posted February 12, 2006 Thanks western,didn't know about discos.what about mods like hybrid turbo if that ones knackered.anyone run a boost tdi? Quote Link to comment Share on other sites More sharing options...
western Posted February 12, 2006 Share Posted February 12, 2006 Afew on here have tweaked the boost setting & fuelling in the injection pump, different turbo's are available, but I'd get it running first with the standard one. Quote Link to comment Share on other sites More sharing options...
daveturnbull Posted February 15, 2006 Share Posted February 15, 2006 If you're going auto, get an auto box from a 300 tdi disco. They have a high-stall torque converter so you get a lot more useable, responsive power. The 200 tdi auto boxes are rubbish - all wrong for the engine. Quote Link to comment Share on other sites More sharing options...
