gelf Posted January 25, 2009 Share Posted January 25, 2009 something has started banging suddenly under the RRC......... any slight pot ho;le make it sound awful, as if something is about to drop off. nothing is loose that i can find, but i was on the side of the road, anyway nursed it home...... i think it may be the self leveling damper........ can the whole lot be ditched, or does it have to have one? Quote Link to comment Share on other sites More sharing options...
bishbosh Posted January 25, 2009 Share Posted January 25, 2009 I haven't heard of a boge strut making banging nosies before. Are you sure the A frame ball joint is OK and done up tight? Also check shock bushes. To answer your question, the strut can be removed. Most struts by now have ceased to function - does your work? To test, put a substantial weight in the boot of the RR - enough so the suspension sags significantly. Measure the bumpstop to axle clearance (rear). Drive around the block a few times. Measure the bumpstop to axle clearance again. If the strut is working the suspension should have self levelled and your second measurement should be bigger than your first. If it is knackered just un bolt it at the top and hack it off the A frame at the bottom * and throw it away. If it is still working, even a bit be very careful removing it as it is under pressure. If it is working and you do remove it you will need to replace the rear springs to avoid the saggy ar$e syndrome. * A tidier way is to remove the centre part of the A frame and replace it with one from a vehicle that does not have a self leveller. Quote Link to comment Share on other sites More sharing options...
custom-conversions Posted January 25, 2009 Share Posted January 25, 2009 something has started banging suddenly under the RRC......... any slight pot ho;le make it sound awful, as if something is about to drop off.nothing is loose that i can find, but i was on the side of the road, anyway nursed it home...... i think it may be the self leveling damper........ can the whole lot be ditched, or does it have to have one? You don't really need the self leveling unit, although if you carry a lot of weight in the back they are helpful. Disco's never had them fitted but did have stiffer rear springs. Its worth checking the rear A-frame ball joint for play though as they can make a knocking noise over bumps. Quote Link to comment Share on other sites More sharing options...
gelf Posted January 25, 2009 Author Share Posted January 25, 2009 just strange that its started from no where. Quote Link to comment Share on other sites More sharing options...
bishbosh Posted January 25, 2009 Share Posted January 25, 2009 My money is still on the A frame ball joint. Quote Link to comment Share on other sites More sharing options...
gelf Posted January 25, 2009 Author Share Posted January 25, 2009 hope your right.......... would it start all of a sudden though? Quote Link to comment Share on other sites More sharing options...
bishbosh Posted January 25, 2009 Share Posted January 25, 2009 Happened to me - the castellated nut came loose (split pin not engaged ) One day no banging and clanging, the next there was. Quote Link to comment Share on other sites More sharing options...
gelf Posted February 4, 2009 Author Share Posted February 4, 2009 oh dear................... rear shock top shock mount had come loose............. what an idiot. Quote Link to comment Share on other sites More sharing options...
bishbosh Posted February 4, 2009 Share Posted February 4, 2009 Excellent! At least it is sorted! Did you check the other side whilst you were there...? Quote Link to comment Share on other sites More sharing options...
