landkeeper Posted January 29, 2009 Share Posted January 29, 2009 i have lost both front sidelights/drivers side rear and all instrument/heater/clock lights if i plug a trailer board in i have side lights on the board everything else seems fine all fuses seem ok any ideas it's a 1995 disco300 tdi manual with 102k on the clock Quote Link to comment Share on other sites More sharing options...
Ivan Posted January 30, 2009 Share Posted January 30, 2009 Not sure but, I believe the Disco had some fusible links somewhere in the engine bay. Maybe one of these has gone. If you search the forum for "fusible link" I am sure there is a post on here somewhere about them. Hopefully a grown up will be along sonn to help. Rgds Ivan Quote Link to comment Share on other sites More sharing options...
Richard Mills Posted January 30, 2009 Share Posted January 30, 2009 I wouls also take a look at the earth strip in the passengers foot well. Take off the side panel and it's at the bottom, it has a number of spade tags on it and one may be burnt out. Usually the heater one is the first to go. Quote Link to comment Share on other sites More sharing options...
landkeeper Posted January 30, 2009 Author Share Posted January 30, 2009 sorted !!!!!!!! a combination of two front sidelight bulbs blown and a duff fuse that looked ok but wasn't righthand sidelight fuse had blown that knocked out the instruments too and the front nearside bulb had gone also that left me with the rear nearside sidelight and a numberplate light also the trailer board was wired for sidelights from the nearside so having both sidelights on it was thriowing me a bit anyway sorted for now although 3 hrs wasted sorting it out in the rain Quote Link to comment Share on other sites More sharing options...
