Tractorboy16 Posted February 3, 2009 Share Posted February 3, 2009 hi, sorting out wiring of my 8274, have the standard motor fitted at the moment and won't be changing for a few months or so so was wondering, would i be able to weld a bolt to the motor casing to act as an earth, underneath the other motor away from the A F1 and F2 connectors? or is it best to earth off the mounting bolt? Many thanks James Quote Link to comment Share on other sites More sharing options...
ciderman Posted February 3, 2009 Share Posted February 3, 2009 Personaly I wouldnt put a welder anywhere near the motor body for fear of de-magnitisation or summat like that, I take it there isnt an earthing point on the lower point of the body , If not then a mounting bolt would be the next choice . Quote Link to comment Share on other sites More sharing options...
Tractorboy16 Posted February 3, 2009 Author Share Posted February 3, 2009 no, no bolt to earth to underneath the motor, you can remove the motor inners from the casing carn't you? James Quote Link to comment Share on other sites More sharing options...
Warthog Posted February 5, 2009 Share Posted February 5, 2009 no, no bolt to earth to underneath the motor,you can remove the motor inners from the casing carn't you? James Welded a 10mm bolt to the casing as you are suggesting, worked perfectly well. But the motor wont get the most out of your winch though, 2.5Hp power output aint that good. The Champion winch motor may be a cheap investment, and lay the old motor to rest Quote Link to comment Share on other sites More sharing options...
Tractorboy16 Posted February 6, 2009 Author Share Posted February 6, 2009 Welded a 10mm bolt to the casing as you are suggesting, worked perfectly well.But the motor wont get the most out of your winch though, 2.5Hp power output aint that good. The Champion winch motor may be a cheap investment, and lay the old motor to rest Cheers for reply, spoke with gigglepin in the end and fitting a bow-motor in a few weeks due to the price increase of the xp to nearly £300 James Quote Link to comment Share on other sites More sharing options...
