51bigG Posted February 3, 2009 Share Posted February 3, 2009 can any one tell me how simple it is to replace the seal between the windscreen and bulkhead? Quote Link to comment Share on other sites More sharing options...
western Posted February 3, 2009 Share Posted February 3, 2009 it's a screen & frame removal job, unbolt from roof & the 2 brackets or hinges at the bulkhead. Quote Link to comment Share on other sites More sharing options...
Les Henson Posted February 3, 2009 Share Posted February 3, 2009 I think you'll find that you'll need to unbolt the roof and raise it a small amount. In theory the screen should tilt inwards once you have released all the fixings, but the corner supports/roof lining prevent that. You could push the bottom out and remove the screen that way, but when you try to put it back in with the new seal fitted - there's not enough clearance to get it in without damaging/bunching the seal. I've never managed to remove/replace a screen without lifting the roof first. Les. Quote Link to comment Share on other sites More sharing options...
