CSW Posted February 5, 2009 Share Posted February 5, 2009 Does any body please know where i can find the Dim Dip relay on my 1997 300TDi Defender. I think it may be faulty because I have no dip beam only full beam. I have checked the switch outputs and all seems ok. swapping the relays below the fuses in the passenger compartment has had no effect. Many thanks Quote Link to comment Share on other sites More sharing options...
western Posted February 5, 2009 Share Posted February 5, 2009 IIRC it's a PINK relay & behind the fusebox below the dash. Quote Link to comment Share on other sites More sharing options...
CSW Posted February 5, 2009 Author Share Posted February 5, 2009 Thank you, I will look at it first thing in the morning. Quote Link to comment Share on other sites More sharing options...
Reynolds_90 Posted February 5, 2009 Share Posted February 5, 2009 When the Dim-Dip relay went on our 300 Tdi, then I found the relay (pink) behind the instrument binacle. No more than a 20min job to change them over. Quote Link to comment Share on other sites More sharing options...
western Posted February 5, 2009 Share Posted February 5, 2009 ah, maybe I'm wrong, apologies. Quote Link to comment Share on other sites More sharing options...
TimR Posted February 5, 2009 Share Posted February 5, 2009 Yep, tucked down inside the binnacle, right side, just below sight. You can also get to it by removing the speaker down by your right knee if you have a radio installed. The Relay is about 20 quid from your friendly Land Rover dealership. Quote Link to comment Share on other sites More sharing options...
CSW Posted February 7, 2009 Author Share Posted February 7, 2009 Thank you for the help & advice, I would have taken hours to find the relay. I reached it through the speaker hole, a replacement relay means I now have dip beam headlights. Quote Link to comment Share on other sites More sharing options...
