yogibear47.lee Posted February 6, 2009 Share Posted February 6, 2009 can it be done a 300 body on a 200 chassis and will i need a test or anything i know i will need to put the chassis plate on the body off the 300 Quote Link to comment Share on other sites More sharing options...
andyb Posted February 6, 2009 Share Posted February 6, 2009 Are you just 'reboding' a 200 with a 300 body or are you 'rechassing' a 300 with a 200 chassis, but swapping the bodies over. The identity should (must) follow the chassis. It is more complex than that but that is the basic 'bottom line'. However, in principal a 300 body should go straight onto a 200 chassis. Certainly the body mounts are all in the same place. Quote Link to comment Share on other sites More sharing options...
ABC Posted February 6, 2009 Share Posted February 6, 2009 hi i think the only differance on the body shell was the inner dash panel and the front panel and some extra holes in the rear floor for rear aircon all the body mounts are the same as both 200 and 300 were built on the same line in B I W Quote Link to comment Share on other sites More sharing options...
Ivan Posted February 7, 2009 Share Posted February 7, 2009 Did this on my old Discovery after someone crashed into it and drove off Originally it was a 2 door 200 series and we fitted it with a 300 series ES body shell. No test required and the insurance company just said if it has an MOT then it's ok by them. Just remember to swap the VIN plate to the new vehicle as the chassis etc is still the same. HTH Ivan Quote Link to comment Share on other sites More sharing options...
