badgerbob Posted February 7, 2009 Share Posted February 7, 2009 hi all i have just bought a 110 double cab special with half a roll cage at the front i would like to put my rooftent on it so what roofrack will i need Quote Link to comment Share on other sites More sharing options...
western Posted February 7, 2009 Share Posted February 7, 2009 a roofrack for 90 would be OK or a 3/4 length rack for a 110. Quote Link to comment Share on other sites More sharing options...
Ben_J85JTY Posted February 7, 2009 Share Posted February 7, 2009 a roofrack for 90 would be OK or a 3/4 length rack for a 110. Be careful about which 90 roof rack if you do go through that route, as ones like the Hannibal, with the solid bar fitted in the gutter will not fit, the gutter is about 2" too long. Also, if you have the roll cage, you may find the brackets wont fit. The Tomb Raider ones were designed to fit on the bars so that might be a start. Brownchurch and Patriot both do roof racks specifically for double cabs. Quote Link to comment Share on other sites More sharing options...
landrover598 Posted February 7, 2009 Share Posted February 7, 2009 Why not fit the tent onto two roof bars, it's what i did as there isn't a roof rack to fit my 100", it also saves a bit of weight up high. Quote Link to comment Share on other sites More sharing options...
badgerbob Posted February 8, 2009 Author Share Posted February 8, 2009 thanks for that great idea only want to use the tent for 2 weeks then it can go back onto the 90 Quote Link to comment Share on other sites More sharing options...
