Cat_J Posted February 15, 2009 Share Posted February 15, 2009 Before I replace the air filter I'd like to know how much oil is supposed to come up out of then breather back into the air intake. I'm assuming little to none but there is a bit more than I'm hope for but not a ridiculous mount. Would it be because the mesh inside is blocked. Can the mesh just be replaced or do I need to replace the whole thing? I notice Allisport do one but it doesn't seem worth it for £80. Cheers. Quote Link to comment Share on other sites More sharing options...
tonka Posted February 15, 2009 Share Posted February 15, 2009 i just cleaned mine with white spirit. took a while to run it through the pipes and get it as clean as possible. then left it to dry for a few days. seems to have stoped the problem. Quote Link to comment Share on other sites More sharing options...
Cat_J Posted February 15, 2009 Author Share Posted February 15, 2009 Can you take the top off to get at the mesh. I shall have a go at that, possibly with some petrol as thats what i usually use to remove oil related things. Got some driveway gunk too so I could just shove everything through it. Does it just pull off? Cheers. Quote Link to comment Share on other sites More sharing options...
zulublue Posted February 16, 2009 Share Posted February 16, 2009 I used for brake disk cleaner from Wurth, it cleaned it out in no time really good stuff. Quote Link to comment Share on other sites More sharing options...
tonka Posted February 16, 2009 Share Posted February 16, 2009 i just pulled off the whole unit. pipes as well. the breather its self didnt seem to obvious how it came apart so i submerged it in the spirit and ran some through the pipes. like i said it worked for me but i would imagine there is a better way of doing it. Quote Link to comment Share on other sites More sharing options...
Cat_J Posted February 16, 2009 Author Share Posted February 16, 2009 Great. I'll have a go at the weekend then. Cheers. Quote Link to comment Share on other sites More sharing options...
western Posted February 16, 2009 Share Posted February 16, 2009 it doesn't come apart, I clean mine in either some solvent from work or parafinn or petrol, just make sure is dry as possible before refitting. Quote Link to comment Share on other sites More sharing options...
defender300td1 Posted February 16, 2009 Share Posted February 16, 2009 you can buy a new one from douglass motors for about £14+vat www.douglassmotors.co.uk Quote Link to comment Share on other sites More sharing options...
Cat_J Posted February 16, 2009 Author Share Posted February 16, 2009 Do the seals need replacing or do you not need to take them out? Quote Link to comment Share on other sites More sharing options...
western Posted February 16, 2009 Share Posted February 16, 2009 there's only 1 O ring seal on the stub that fits into the rocker cover, if it's deformed then best to replace it. Quote Link to comment Share on other sites More sharing options...
