fatforbes Posted February 21, 2009 Share Posted February 21, 2009 Had a bit of an accident and somehow my wheel nuts came loose and I lost a wheel, luckily I was only doing 30mph and felt that something wasn't right before it happened, anyway I think i mashed the wheel bearings and i've gone to replace them today and can't remove the hub. the caliper, both big nuts and the outer spacer are off but the spacer thats just infront of the bearing won't budge, even after much hammering and using a puller theres no movement. what can I do?? Quote Link to comment Share on other sites More sharing options...
white90 Posted February 21, 2009 Share Posted February 21, 2009 Put the wheel back on then try rocking it off. most likely the bearing has seized on the stub axle. Quote Link to comment Share on other sites More sharing options...
