maxtherotti Posted February 25, 2009 Share Posted February 25, 2009 hi all my 98 300tdi manual has only got solid discs all round and the brakes are defo not as good as they were on my rrc auto is changing the fronts to vented discs/calipers a worthwile mod? what else would i need to change other than the discs/pads/calipers?? i am planning on doing a fair bit of towing with this car too rob Quote Link to comment Share on other sites More sharing options...
stageonesimmo Posted February 25, 2009 Share Posted February 25, 2009 As far as I remember, the calipes and discs/pads from a vented 110 are a straight swap - no pipework adjustments or anything else necessary - they are better than the disco set-up as they have bigger pistons - this can lead to increased pedal travel due to the mastercylinder needing to displace more fluid to drive the pistons out............... Quote Link to comment Share on other sites More sharing options...
andyb Posted February 25, 2009 Share Posted February 25, 2009 Have you done the easy things, like bleed the brakes to renew/refresh the brake fluid. How about checking the flexi hoses? Swap in a new master cylinder? Quote Link to comment Share on other sites More sharing options...
maxtherotti Posted February 25, 2009 Author Share Posted February 25, 2009 i dont want a soft pedal mine is ok as it is and the brakes do work ok just not as well as the range rover ones did (i allways thought they were very good on that miles better than any rrc/disco i have had before) think i will put new braided hoses on it and new fluid see if that helps firm the pedal up a bit ?? rob Quote Link to comment Share on other sites More sharing options...
andyb Posted February 26, 2009 Share Posted February 26, 2009 Braided hoses and a master cylinder rebuild kit did wonders for my brakes. Also did seals in calipers and added stainless steel pistons. Quote Link to comment Share on other sites More sharing options...
stageonesimmo Posted February 26, 2009 Share Posted February 26, 2009 Plus, keep an eye on the play in the bearings - slack in the bearings can allow the disc to run-out vertically, this pushes the pads and pistons back in a touch resulting in the system having to 'take-up the slack' on the first push of the pedal - you need more pedal travel before the pads actuall fully contact the disc. Its more noticable on the fronts as the front system is mainly responsible for pedal travel and feel as its the first piston to pressurise............ I've not done it yet, but braided hoses are a very good way to firm up the pedal. Quote Link to comment Share on other sites More sharing options...
maxtherotti Posted February 26, 2009 Author Share Posted February 26, 2009 no play at all in any bearings i dont think there is anything wrong as such with my brakes they just aint brilliant lol rob Quote Link to comment Share on other sites More sharing options...
