Comical Engineer Posted February 25, 2009 Share Posted February 25, 2009 Mini CE No.2 has managed to jam my back door lock on the Disco (300tdi) by grabbing the handle at the exact time I was unlocking it with the fob. Can't open the door either from inside or out and the outside handle is jammed in the up position. Any help gratefully received as I need to take a pile of stuff to the tip at the weekend! Quote Link to comment Share on other sites More sharing options...
V8CAMEL Posted February 25, 2009 Share Posted February 25, 2009 Mini CE No.2 has managed to jam my back door lock on the Disco (300tdi) by grabbing the handle at the exact time I was unlocking it with the fob.Can't open the door either from inside or out and the outside handle is jammed in the up position. Any help gratefully received as I need to take a pile of stuff to the tip at the weekend! easy peasy pop the landrover logo off the handle. there is a nice little small bladed screw driver shaped gap right at the bottom. you will then be able to push the mechanism down and should be able to open the door paul Quote Link to comment Share on other sites More sharing options...
Comical Engineer Posted February 25, 2009 Author Share Posted February 25, 2009 Star! Will give it a try in the morning! Thanks. Quote Link to comment Share on other sites More sharing options...
V8CAMEL Posted February 27, 2009 Share Posted February 27, 2009 Star!Will give it a try in the morning! Thanks. did it work Quote Link to comment Share on other sites More sharing options...
DefcoL Posted February 27, 2009 Share Posted February 27, 2009 easy peasypop the landrover logo off the handle. there is a nice little small bladed screw driver shaped gap right at the bottom. you will then be able to push the mechanism down and should be able to open the door paul Paul... I do hope this doesn't work when locked Quote Link to comment Share on other sites More sharing options...
J@mes Posted February 27, 2009 Share Posted February 27, 2009 mine does this occasionally when the spring runs out of wd40! keep a small table knife in the drivers door pocket for the occassion! Quote Link to comment Share on other sites More sharing options...
V8CAMEL Posted February 27, 2009 Share Posted February 27, 2009 in answer to a pm all this does is give you acess to the "handle" bit which has stuck in the up postion to allow you release the handle. you still need the key etc to unlock the vehicle. Quote Link to comment Share on other sites More sharing options...
stageonesimmo Posted February 28, 2009 Share Posted February 28, 2009 You can infact do the same thing without removing the badge by inserting a screwdriver in at the right angle - just that removing the badge makes it easier to do and you can see the pivot points for the handle better. Quote Link to comment Share on other sites More sharing options...
st3v3_c Posted March 2, 2009 Share Posted March 2, 2009 Did you get this open? I had the same problem and might be able to talk you through it - it's difficult to explain. PM me dude Quote Link to comment Share on other sites More sharing options...
