Froggie Posted March 19, 2009 Share Posted March 19, 2009 I have recently replaced my air springs with coil springs, so have no use for the air supply unit. .... thats not exactly true, because if I could use it in situe to inflate my inflatable matresses and even possibly my tyres, i would be extatic!!! Is it possible (is it powerfull enough) to inflate a blow up bed (bed... not doll!!!!) ? Also i would have liked to use the switches in the disco (ride height etc) to turn it on and off, does anyone have any thoughts/experiences with this type of modification. thanks Steve Quote Link to comment Share on other sites More sharing options...
q-rover Posted March 19, 2009 Share Posted March 19, 2009 Why switch it? Simply add a air resevoir tank and route the supply into that. It will then act as if it has 1 large airspring and will keep it topped up without external influence. You then simply fill from the resevoir rather than direct from the compressor. Quote Link to comment Share on other sites More sharing options...
BogMonster Posted March 19, 2009 Share Posted March 19, 2009 see here http://forums.lr4x4.com/index.php?showtopic=39894 Quote Link to comment Share on other sites More sharing options...
