travelbug Posted March 20, 2009 Share Posted March 20, 2009 Hi there, I have a 1989 110 Defender that has been modified for off road use and I am thinking of putting the suspension back to standard. The rear anti roll bar has been removed and I want to get another one secondhand. I have the chance of one off a Disco 1. Can anyone tell me please if this would be the same as the Defender? Thanks for any help. Quote Link to comment Share on other sites More sharing options...
headhunter Posted March 20, 2009 Share Posted March 20, 2009 I suspect not, however put a request in the Wanted section and I am sure someone from here will have what you want. John Quote Link to comment Share on other sites More sharing options...
Les Henson Posted March 20, 2009 Share Posted March 20, 2009 Defender Front NTC6837 Rear To (V) MA960429 = NRC6221. From (V)MA960430 = ANR4344 Disco 1 Front To (V) LA081991 = NTC6936. From (V) MA081992 = NTC6837 Rear To (V) MA139686 = NRC6221. From (V) MA139687 = ANR4344 Les. Quote Link to comment Share on other sites More sharing options...
headhunter Posted March 20, 2009 Share Posted March 20, 2009 Les Thanks I was not sure myself, will travelbug require new links or will the Disco ones work OK. On my 110 which started life as a utility there were no mountings on the front for an ARB, so I bought some to be welded on, then decided not to. (I still have them if anyone is interested) I then removed the rear ARB which I had fitted (since sold), and up rated the springs to the 500kg OME's. There is very little body roll and surprisingly the ride is not stiff with the HD springs. I have OME shocks all round and am very pleased with the whole suspension set up, without any ARB's. As it left the factory as a utility without ARB's I am not in contravention of the MOT, despite the vehicle now being a CSW! John Quote Link to comment Share on other sites More sharing options...
Dave K Posted March 20, 2009 Share Posted March 20, 2009 I've just fitted an ARB to a 1994 SW using a Mk1 Discovery part. The only difference is the two brackets which mount the bar to the chassis. The Disco version only has two holes per bracket. The LR/Defender item has four. Quote Link to comment Share on other sites More sharing options...
travelbug Posted March 21, 2009 Author Share Posted March 21, 2009 Hi there, I have a 1989 110 Defender that has been modified for off road use and I am thinking of putting the suspension back to standard. The rear anti roll bar has been removed and I want to get another one secondhand. I have the chance of one off a Disco 1. Can anyone tell me please if this would be the same as the Defender? Thanks for any help. Thanks Guys for the advice. Looks like the ARB will be OK and all I need is the 4 hole brackets for the chassis. Paul Quote Link to comment Share on other sites More sharing options...
