GUYZER90 Posted March 25, 2009 Share Posted March 25, 2009 Hi folks , Does rot in the external face of a defender rear cross member mean MOT failure ? or is not an issue ? Cheers Guy. Quote Link to comment Share on other sites More sharing options...
Dave W Posted March 25, 2009 Share Posted March 25, 2009 Hi folks ,Does rot in the external face of a defender rear cross member mean MOT failure ? or is not an issue ? Cheers Guy. Yes, it's a structural member that supports the rear tub so needs to be sound. Quote Link to comment Share on other sites More sharing options...
GUYZER90 Posted March 25, 2009 Author Share Posted March 25, 2009 Yes, it's a structural member that supports the rear tub so needs to be sound. I thought as much, this means im gonna be busy!! cheers for the reply. Regards Guy. Quote Link to comment Share on other sites More sharing options...
jimmy_neutron Posted March 25, 2009 Share Posted March 25, 2009 I thought as much, this means im gonna be busy!! cheers for the reply.Regards Guy. If its gone in the rear face then get the member with legs on it cos you will likely need the legs as well. Also makes em easier to fit. Quote Link to comment Share on other sites More sharing options...
GUYZER90 Posted March 25, 2009 Author Share Posted March 25, 2009 If its gone in the rear face then get the member with legs on it cos you will likely need the legs as well.Also makes em easier to fit. From what i can see it's only gone on the external face just below the side of the door both side's , so hopefully might get away with cutting out a sectoin and welding abit in , then i think before next mot i will get a new cross member on there. Quote Link to comment Share on other sites More sharing options...
