driftanimal Posted March 30, 2009 Share Posted March 30, 2009 hi guys, basically wondering if the Td5 intercooler will fit a 300tdi .... as im assuming the Td5 intercooler is larger than teh 300tdi?? cheers in advance Quote Link to comment Share on other sites More sharing options...
BogMonster Posted March 30, 2009 Share Posted March 30, 2009 Anything will "fit" with the will to do so but not easily in this case - the pipes are on opposite sides on a Td5 instead of both on one side on a 300, so will be a fair bit of extra intake plumbing required to take the pipework from the right hand side of the intercooler to the intake on the left side of the engine. A better all round solution if you want to upgrade would be a proper one from Brunel/Allisport etc which is intended to fit a 300 in the first place. I don't even know how much extra cooling a Td5 one provides but while it is bigger it is nowhere near as big as a full width one from the aftermarket suppliers. Quote Link to comment Share on other sites More sharing options...
driftanimal Posted March 30, 2009 Author Share Posted March 30, 2009 Anything will "fit" with the will to do so but not easily in this case - the pipes are on opposite sides on a Td5 instead of both on one side on a 300, so will be a fair bit of extra intake plumbing required to take the pipework from the right hand side of the intercooler to the intake on the left side of the engine. A better all round solution if you want to upgrade would be a proper one from Brunel/Allisport etc which is intended to fit a 300 in the first place. I don't even know how much extra cooling a Td5 one provides but while it is bigger it is nowhere near as big as a full width one from the aftermarket suppliers. thanks chap .... just looking for A cheaper way instead of paying out the £250+ for an intercooler Quote Link to comment Share on other sites More sharing options...
cipx2 Posted March 30, 2009 Share Posted March 30, 2009 driftanimal, here are some threads for you read: http://forums.lr4x4.com/index.php?showtopic=21157 http://forums.lr4x4.com/index.php?showtopic=8488 http://forums.lr4x4.com/index.php?showtopic=8274 Quote Link to comment Share on other sites More sharing options...
