stuck Posted April 2, 2009 Share Posted April 2, 2009 Thinking about instaling a Real Steel "Stump Puller" cam in my rebuilt 4.6 with stage 2 heads. Will also order the relevant valve springs, valve guides, lifters, adjustable rods etc... Looking for maximum grunt at around 4500 RPM, am I on the right track ? Many thanks, Mick. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted April 2, 2009 Share Posted April 2, 2009 Looking for maximum grunt at around 4500 RPM, am I on the right track ? Are you racing it? 'cos if not I'd say you want the grunt much much lower, and I think the stump puller does indeed put it much lower. I believe Real Steel even have a telephone that you can use to ask their advice on such things Quote Link to comment Share on other sites More sharing options...
Dave W Posted April 2, 2009 Share Posted April 2, 2009 What do you intend using it for ? For off road max torque at 4500 seems a bit high or do you mean power rather than torque when you say "grunt" ? Quote Link to comment Share on other sites More sharing options...
stuck Posted April 3, 2009 Author Share Posted April 3, 2009 What do you intend using it for ?For off road max torque at 4500 seems a bit high or do you mean power rather than torque when you say "grunt" ? Sorry I meant BHP not torque. Quote Link to comment Share on other sites More sharing options...
steve_d Posted April 3, 2009 Share Posted April 3, 2009 The spec sheet offers max torque at 3500. See if they have a graph so you can check the curve. If it is fairly flat then you should have plenty of torque from about 1500. Stump pulling is torque not HP. Steve Quote Link to comment Share on other sites More sharing options...
