jason110 Posted April 6, 2009 Share Posted April 6, 2009 just a quick one, ive got an oil leak (surprise, surprise!), its on the rear hub, ive taken the dust cap that protects the ends of the splines with the circlip on the end, and it seems to be coming from there. before, i go ordering a load of seals i may not need, has anyone got an idea which one it could be? has anyone done this before and got any pointers?? thanks jase Quote Link to comment Share on other sites More sharing options...
western Posted April 6, 2009 Share Posted April 6, 2009 nothing to worry about, oil at that end is good for the splines that drive the wheels, put some grease inside the plastic centre cap & refit. Tip, put the cap in very hot water, then dry it, put some wheel bearing grease in & fit to hub, if the cap is split just fit a new one, warming it allows you to fit it easier & as it cools it grips the hub better. Quote Link to comment Share on other sites More sharing options...
jason110 Posted April 6, 2009 Author Share Posted April 6, 2009 thanks for the that will do it this weekend ! much appreciated jase Quote Link to comment Share on other sites More sharing options...
