fuel pump
timmymac
Don't forget that some fuel pumps 'suck' vs others 'push', you need the right
one so that the pump doesn't pass away soon after fitting it,
the in tank RR ones can be had 2nd hand are are quite modifyable
The RR pump itself goes to around 120 PSI but the PRV drops this to around mid 30's
too weak a pump ie one at 40 psi flat out may not pump enough to keep it happy at full chat :)
Nige
