R380 box, pto drive oil seal.
Is there anyone out there who can tell me what the part number is for the oil seal where the winch pto drive leaves the gearbox on a 99 Td5,Defender. Shaft is 19mm. Casing internal diameter is 32mm. Is it a standard size get anywhere seal or LR part only?
Thanks
Graham.
Hey?
Is there a PTO shaft output on a R380?
How do you get that to work? What type of winch can be fitted to that?
I am very interested
As western says, its on the back of the transfer box, the output shaft runs up the inside edge of the chassis on the passenger side. I have a superwinch H14W fitted to the front of my landy.
