Nilsh Posted April 16, 2009 Share Posted April 16, 2009 I want to install a detroit locker in my rear axle on a 1998 110". What kind of diff carrier bearings do i need? Quote Link to comment Share on other sites More sharing options...
jcwcooper Posted April 17, 2009 Share Posted April 17, 2009 You should find all the info you need here, if not give them a bell http://www.ashcroft-transmissions.co.uk/ Dave. Quote Link to comment Share on other sites More sharing options...
western Posted April 17, 2009 Share Posted April 17, 2009 truetrak diff http://www.ashcroft-transmissions.co.uk/part_5.html Quote Link to comment Share on other sites More sharing options...
Nilsh Posted April 18, 2009 Author Share Posted April 18, 2009 I have been locking on Ashcroft, but i dont understand if i must have the RTC3095 bearings or not? Quote Link to comment Share on other sites More sharing options...
western Posted April 18, 2009 Share Posted April 18, 2009 easy way to find out, get the axle serial number off the casing & then ring Ashcrofts & ask to speak to Dave or Ian. Quote Link to comment Share on other sites More sharing options...
Nilsh Posted April 18, 2009 Author Share Posted April 18, 2009 easy way to find out, get the axle serial number off the casing & then ring Ashcrofts & ask to speak to Dave or Ian. It`s not so easy to ring and talk english when you are from Norway;) Thats why i was hoping that somebody could tell me if i have to change the bearings or not. I`m gonna buy the locker att paddocks, and dont want to bother Aschroft with questions. Quote Link to comment Share on other sites More sharing options...
western Posted April 18, 2009 Share Posted April 18, 2009 Dave is a member of this forum, so hopefully he'll drop in & leave a top class reply. Quote Link to comment Share on other sites More sharing options...
Nilsh Posted April 19, 2009 Author Share Posted April 19, 2009 Dave is a member of this forum, so hopefully he'll drop in & leave a top class reply. Lets hope that. Quote Link to comment Share on other sites More sharing options...
western Posted April 19, 2009 Share Posted April 19, 2009 You could send him a PM Quote Link to comment Share on other sites More sharing options...
Aragorn Posted April 19, 2009 Share Posted April 19, 2009 or email him. Quote Link to comment Share on other sites More sharing options...
rick Posted April 20, 2009 Share Posted April 20, 2009 You don't have to change the bearings if they are OK, just pull the centre and split the hemisphere, pull the planetary gears out and install the No Spin centre and reinstall. Ideally you spread the case or compress it top to bottom (spreads it sideways, there is a certain amount of pre-load on the bearings) but a couple of tyre levers will get the centre out too, and some gentle persuasion with a copper or soft face bashing implement will get it back in. Quote Link to comment Share on other sites More sharing options...
Nilsh Posted April 22, 2009 Author Share Posted April 22, 2009 You don't have to change the bearings if they are OK, just pull the centre and split the hemisphere, pull the planetary gears out and install the No Spin centre and reinstall.Ideally you spread the case or compress it top to bottom (spreads it sideways, there is a certain amount of pre-load on the bearings) but a couple of tyre levers will get the centre out too, and some gentle persuasion with a copper or soft face bashing implement will get it back in. Thank you. Is it just the internals of the diffcasing that is changed? Do you got a picture of the locker? Quote Link to comment Share on other sites More sharing options...
