spudd Posted April 20, 2009 Share Posted April 20, 2009 Hi newbie question time. i have the bias top plate off waiting for a new one to arrive.im thinking whilst its stripped down i could drain off gear box oil and refill from the top.anyone know if this is viable. spudd Quote Link to comment Share on other sites More sharing options...
BogMonster Posted April 21, 2009 Share Posted April 21, 2009 I think so, pretty sure it will just run down through Quote Link to comment Share on other sites More sharing options...
spudd Posted April 21, 2009 Author Share Posted April 21, 2009 I think so, pretty sure it will just run down through thanks will let you know. main problem now is finding mtf 94. spudd Quote Link to comment Share on other sites More sharing options...
martinhollings Posted April 22, 2009 Share Posted April 22, 2009 mtf94 is the name given to it by texico most oil makers do there version of the same oil i no that carlube do mtf94 but i used castrol in my box got it from halfords see link http://www.castrol.com/castrol/iframe.do?c...ntentId=7044829 and you can fill it from the top of the box because i have done it when i drained the oil and could not get the filler out Quote Link to comment Share on other sites More sharing options...
spudd Posted April 22, 2009 Author Share Posted April 22, 2009 mtf94 is the name given to it by texico most oil makers do there version of the same oil i no that carlube do mtf94 but i used castrol in my box got it from halfords see linkhttp://www.castrol.com/castrol/iframe.do?c...ntentId=7044829 and you can fill it from the top of the box because i have done it when i drained the oil and could not get the filler out thank you. did you pull the gear stick out or remove the carrier plate to get the oil in. spudd Quote Link to comment Share on other sites More sharing options...
