350ypvs Posted May 2, 2009 Share Posted May 2, 2009 Can anybody please tell me where the handbrake adjuster is on the drum on a 97 300tdi. I have read the haynes manual but can not see an adjuster anywhere on the drum . Any help would be most appreciated. Gary Quote Link to comment Share on other sites More sharing options...
rhydgte Posted May 2, 2009 Share Posted May 2, 2009 Can anybody please tell me where the handbrake adjuster is on the drum on a 97 300tdi.I have read the haynes manual but can not see an adjuster anywhere on the drum . Any help would be most appreciated. Gary It is on the back of the drum (side nearest to transfer box!) Quote Link to comment Share on other sites More sharing options...
stageonesimmo Posted May 2, 2009 Share Posted May 2, 2009 its at the base of the back-plate in the 6 o'clock position - you're looking for a 17mm bolt head in a recess at the base of the plate - its the only object down in that area........... Quote Link to comment Share on other sites More sharing options...
350ypvs Posted May 3, 2009 Author Share Posted May 3, 2009 its at the base of the back-plate in the 6 o'clock position - you're looking for a 17mm bolt head in a recess at the base of the plate - its the only object down in that area........... Saw the bolt head but was looking for the standard square adjuster as shown in the Haynes manual. Thanks for that i'll get it done today. Quote Link to comment Share on other sites More sharing options...
