ian_s Posted May 8, 2009 Share Posted May 8, 2009 so i found a small problem with my 200tdi, the crankshaft moves back and forth by quite a large amount. i dont have a dial gauge, but i measured it with a ruler to be just under 1mm. i'm guessing this is a bit too much, as the book reckons about 0.25mm maximum is it possible to change the thrust bearings that control the endfloat without removing the engine? Quote Link to comment Share on other sites More sharing options...
western Posted May 8, 2009 Share Posted May 8, 2009 nope, the ladder frame has to be removed as do the sump & oil pump for access to the main bearing caps. & to remove those bits means engine out job. as bolts from the flywheel housing go in to the rear of the ladder frame. Quote Link to comment Share on other sites More sharing options...
DaleGreaves Posted May 15, 2009 Share Posted May 15, 2009 so i found a small problem with my 200tdi, the crankshaft moves back and forth by quite a large amount.i dont have a dial gauge, but i measured it with a ruler to be just under 1mm. i'm guessing this is a bit too much, as the book reckons about 0.25mm maximum is it possible to change the thrust bearings that control the endfloat without removing the engine? The crank is not snaped as it i had a 200tdi and the pully had some right movment on it when i striped it it had snapped about an inch and half from the end Quote Link to comment Share on other sites More sharing options...
ian_s Posted May 29, 2009 Author Share Posted May 29, 2009 The crank is not snaped as it i had a 200tdi and the pully had some right movment on it when i striped it it had snapped about an inch and half from the end i dont think it can be, as the engine runs. i'm pretty sure if the crank had snapped it wouldnt start at all Quote Link to comment Share on other sites More sharing options...
