HotRod Posted May 11, 2009 Share Posted May 11, 2009 Probably my own fault for neglecting it, but came to use my front mounted winch yesterday and it was dead. I'll admit it hasn't been used since last year and the Landy has been sitting outside, so... I'd appreciate general advice on basics for troubleshooting the fault and keeping it running Many thanks Quote Link to comment Share on other sites More sharing options...
Guest noggy Posted May 11, 2009 Share Posted May 11, 2009 what noise did the winch make if any? any humming? or nothing? are the solenoids stuck? or is the winch motor seized? Quote Link to comment Share on other sites More sharing options...
HotRod Posted May 11, 2009 Author Share Posted May 11, 2009 what noise did the winch make if any?any humming? or nothing? are the solenoids stuck? or is the winch motor seized? Not a sausage, no clicks or whirring. I doubt the motor is seized as it has been fine, but more likely water/dirt into the electrics? Not sure where to start.... Quote Link to comment Share on other sites More sharing options...
chrism Posted May 11, 2009 Share Posted May 11, 2009 What winch is it? My superwinch ep9 seized up solid after i left it in the shed for about 12months It was the brake that seized up, all i did was take the cover off and give it a good thrashing with a hammer and that freed it up Quote Link to comment Share on other sites More sharing options...
Night Train Posted May 11, 2009 Share Posted May 11, 2009 If there are no clicks then it could be no feed to activate the solenoids. Check the connections to the remote to make sure that it is getting a trigger voltage back to the solenoids. Quote Link to comment Share on other sites More sharing options...
andyb Posted May 12, 2009 Share Posted May 12, 2009 Simon, On top of the motor there should be 3 big cables, black and two reds. One is the common and the other two are powered individually for in and out. Use a multi-meter and check that you get 12v across black and one red for either in or out on the remote. If not take the lid off the winch and you will see the solenoids. You can power these individually with test wire and you should hear/see them click. I assume that the free-spool works and it isn't (as suggested) just a stuck drum brake. HTH Quote Link to comment Share on other sites More sharing options...
HotRod Posted May 13, 2009 Author Share Posted May 13, 2009 Thanks for all that - plenty to try cheers Simon Quote Link to comment Share on other sites More sharing options...
