swampduck Posted May 14, 2009 Share Posted May 14, 2009 Hi can anyone help? I have a 2002 td5 disco, whilst driving home it lost all power and started to smoke. It starts up straight away from hot or cold and idles fine but when you try to rev it up it gets to 1200 rpm and starts to misfire and just makes a lot of grey smoke. I've checked the wiring loom to the injectors and ecu and found the usual oil ingress, I've cleaned the conectors with a toothbrush and brake cleaner but this made no difference at all, I have had the ecu scanned for codes but none stored, the wastegate is working as is the map sensor, airflow meter and fuel pump. I have now run out if ideas and would appreciate any help whatsoever. Cheers. Quote Link to comment Share on other sites More sharing options...
BogMonster Posted May 14, 2009 Share Posted May 14, 2009 Have you changed the harness inside the rocker cover that feeds the injectors? If not you need to do this, just cleaning that one won't help. It's only about 40 quid or so and easy to change, clean the plug on the head and the red ECU plug again at the same time and clean both again in a couple of weeks as more oil will come out. Quote Link to comment Share on other sites More sharing options...
Les Henson Posted May 14, 2009 Share Posted May 14, 2009 Bogmonster - is that harness AMR6103 and O-rings (x2) NYX100080 ? Les. Quote Link to comment Share on other sites More sharing options...
BogMonster Posted May 14, 2009 Share Posted May 14, 2009 That's the harness part number - not sure about the O-rings. Ralph!! Where are you? Quote Link to comment Share on other sites More sharing options...
Les Henson Posted May 14, 2009 Share Posted May 14, 2009 I got the numbers off EPC, so they are right. Les. Quote Link to comment Share on other sites More sharing options...
BogMonster Posted May 14, 2009 Share Posted May 14, 2009 Are you putting a Td5 in Flapjack or Flatpack or whatever its called? Quote Link to comment Share on other sites More sharing options...
Les Henson Posted May 15, 2009 Share Posted May 15, 2009 No - just a job to do on a customers vehicle. Les. Quote Link to comment Share on other sites More sharing options...
smo Posted May 15, 2009 Share Posted May 15, 2009 In tank fuel pump failure produces exactly these symptoms, if you have no luck wiht the injector loom then my money is definately on this. Quote Link to comment Share on other sites More sharing options...
BogMonster Posted May 15, 2009 Share Posted May 15, 2009 In tank fuel pump failure produces exactly these symptoms, if you have no luck wiht the injector loom then my money is definately on this. The harness is cheaper though - but you're right the fuel pressure is the next thing to check if that doesn't work. Quote Link to comment Share on other sites More sharing options...
smo Posted May 15, 2009 Share Posted May 15, 2009 I had the exact symptoms from a failed pump on one i borrowed! Definatly recommend cleaning or better still, replacing the harness first because if it has the oil problem it needs doing regardless Quote Link to comment Share on other sites More sharing options...
