mrtash Posted May 19, 2009 Share Posted May 19, 2009 My passenger window goes all the way up then seems to click and bounce back down slightly, if you hold the up button on the electrics. It just appears not to know when to stop. Any ideas please Pete Quote Link to comment Share on other sites More sharing options...
BogMonster Posted May 20, 2009 Share Posted May 20, 2009 Sounds like the regulator is slipping which probably means you should budget for a new one fairly soon. If you take the door trim off and recreate the problem it should be obvious what is happening. Quote Link to comment Share on other sites More sharing options...
SPendrey Posted May 20, 2009 Share Posted May 20, 2009 Mine did the same, a new regulator is only 25quid and about an hour's work. Prepare with some tape to hold the glass up (which you'll need to lower to remove the regulator), some new door panel push-pin thingys, and some gloves 'cos there's some sharp metal edges in the door! Good luck. Quote Link to comment Share on other sites More sharing options...
mrtash Posted May 20, 2009 Author Share Posted May 20, 2009 Thank for the advive will have a shufty at the week end Quote Link to comment Share on other sites More sharing options...
