If i do the following will i be able to get 33,s on !!
lurch
Hi all I am after some advice been searching and reading for hours.. What i want to do is get 33,s on the disco i just got and need to see what mods will need to be done here is what i had planned will it do the job.
+2" springs
2" spring spacers
1" Body lift
+5" Shocks
6 Deg Castor corected radius arms and trailing arms
Adjustable panhard rod
Wide ange propshafts
Extended break lines
30mm Wheel spacers
So if I do that will I be able to get 33's on it without having to hack out loads of the body and still be able to turn corners!!!
Tyre is 305/70/16 or (33X12.5X16)
If the 33's wont fit what size would you say would fit
I am not the most technical person in the world so if you could give any responses in a easy to understand way
Cheers Nathan
+2" springs
2" spring spacers
1" Body lift
+5" Shocks
30mm Wheel spacers
Cheers Nathan
i should think with 4" lift and 1" body lift they should fit
i had a 4" lift and 2" body lift on my disco with 37" boggers , mine is a 3 door and the arches have been cut lots tho
u may have to cut abit from the arches
is it a 5 or 3 door ?
my missis has 33" on her 3 door rrc with a 4" lift and they fit ok , just need to trim the arches at the bottom corners
using 30mm spacers u shouldnt have a problem with steering
A guy in our club runs 35x14.5 boggers with 2" suspension + 2" body lift with lots of cutting.
Other buy runs 33x12.5 bfg with 3" suspension + 1" bodylift and again with fender cutting.
For narrower tyres less cutting required.
its a 5 door thanks for the info from what you have said with a bit of triming i may get away with 35's then..
being a 5 door u may have more of a problem with rubbing , best thing is 2 get sum arches and get the grinder out , take as much as u can out the rear doors
