grumbleweed Posted May 25, 2009 Share Posted May 25, 2009 How hot should the wheel bearing get- i have adjusted mine as there was some play in the front ones, and after a drive, it is hot to touch. I didn't check how hot it was before i adjusted them. They are now well greased- should i worry? It isn't too hot to keep your finger on it, but hot nonetheless!! I did them up as it says until it starts to bind, then undid it a bit. Quote Link to comment Share on other sites More sharing options...
BogMonster Posted May 25, 2009 Share Posted May 25, 2009 How quickly is it getting hot? Warm after a long drive I wouldn't be too worried about, hot after a couple of miles would suggest it is too tight. Quote Link to comment Share on other sites More sharing options...
grumbleweed Posted May 25, 2009 Author Share Posted May 25, 2009 How quickly is it getting hot? Warm after a long drive I wouldn't be too worried about, hot after a couple of miles would suggest it is too tight. have backed it off a touch- much better now after a 10 mile hard drive. Much more confident that it is ok now!! Quote Link to comment Share on other sites More sharing options...
Adi Posted May 25, 2009 Share Posted May 25, 2009 How hot should the wheel bearing get- i have adjusted mine as there was some play in the front ones, and after a drive, it is hot to touch.I didn't check how hot it was before i adjusted them. They are now well greased- should i worry? It isn't too hot to keep your finger on it, but hot nonetheless!! I did them up as it says until it starts to bind, then undid it a bit. i have a similar query...the hub caps(the brass ones)on the rear wheels on my 110...become bearably hot...after a drive....whereas the hub caps on the front wheels remain at the normal surrounding temperature or slightly warm I have not opened anything,like you did but this peculiar thing i noticed after i read your query here. Any ideas as to whats happening...and what i should do? cheers Adi Quote Link to comment Share on other sites More sharing options...
grumbleweed Posted May 25, 2009 Author Share Posted May 25, 2009 i have a similar query...the hub caps(the brass ones)on the rear wheels on my 110...become bearably hot...after a drive....whereas the hub caps on the front wheels remain at the normal surrounding temperature or slightly warmI have not opened anything,like you did but this peculiar thing i noticed after i read your query here. Any ideas as to whats happening...and what i should do? cheers Adi you can take the rear half-shafts out and grease up the bearings. Might be just a little dry! Quote Link to comment Share on other sites More sharing options...
