Adi Posted June 21, 2009 Share Posted June 21, 2009 hey all Rebuilding a 2 1/2 Diesel....i am confused in what order to connect the fuel system...ie.. fuel tank->filter->mechanical lift pump->injector pump or is it fuel tank->mech. lift pump->filter->injector pump Also whats the exact procedure for priming the fuel system? Thanks cheers Quote Link to comment Share on other sites More sharing options...
Les Henson Posted June 22, 2009 Share Posted June 22, 2009 Tank to lift pump. Lift pump to filter. Filter to Inj pump. Return from inj pump to filter. Spill rail to either filter or back to tank. Prime to bleed on the filter, then bleed to inj pump. Bleed each injector in turn, then crank the engine until it starts. Les. Quote Link to comment Share on other sites More sharing options...
Adi Posted June 22, 2009 Author Share Posted June 22, 2009 Tank to lift pump. Lift pump to filter. Filter to Inj pump. Return from inj pump to filter. Spill rail to either filter or back to tank.Prime to bleed on the filter, then bleed to inj pump. Bleed each injector in turn, then crank the engine until it starts. Les. Thanks les ....correct me if am wrong... wont the little debris in the tank screw up the diaphragm inside the lift pump, if the pump sucks diesel directly from tank,when the filter is fitted after the lift pump?? Quote Link to comment Share on other sites More sharing options...
TheRecklessEngineer Posted June 22, 2009 Share Posted June 22, 2009 Thanks les ....correct me if am wrong...wont the little debris in the tank screw up the diaphragm inside the lift pump, if the pump sucks diesel directly from tank,when the filter is fitted after the lift pump?? No, it won't. B) Quote Link to comment Share on other sites More sharing options...
Snagger Posted June 22, 2009 Share Posted June 22, 2009 Thanks les ....correct me if am wrong...wont the little debris in the tank screw up the diaphragm inside the lift pump, if the pump sucks diesel directly from tank,when the filter is fitted after the lift pump?? As Les said, it won't. The pick-up pipes in the tanks have gauze stariners on them to keep any significant sediment or FOD out of the lines. Quote Link to comment Share on other sites More sharing options...
