pist0nbr0ke Posted June 22, 2009 Share Posted June 22, 2009 Hi all, Just trying to order a clutch slave cylinder but need to know the part number. The one i have currently got on my 1994 300tdi defender is square at the back where the pipe screws in, and the thread starts imeadiatly with no shoulder. One i have already been given has this shoulder and doesnt screw in at all. Also while im at it i might as well change the master cylinder. Any ideas of what part numbers they are? Cheers Neil Quote Link to comment Share on other sites More sharing options...
foggy3061 Posted June 22, 2009 Share Posted June 22, 2009 Hi all,Just trying to order a clutch slave cylinder but need to know the part number. The one i have currently got on my 1994 300tdi defender is square at the back where the pipe screws in, and the thread starts imeadiatly with no shoulder. One i have already been given has this shoulder and doesnt screw in at all. Also while im at it i might as well change the master cylinder. Any ideas of what part numbers they are? Cheers Neil 550732 or STC100410 (550732 supersedes to STC100410) Hope that helps Edit: It appears that STC100410 now supersedes to STC100411, see here: Clutch master cylinders Quote Link to comment Share on other sites More sharing options...
pist0nbr0ke Posted June 22, 2009 Author Share Posted June 22, 2009 hi there Foggy, Any idea as to the slave cylinder? cheers Neil Quote Link to comment Share on other sites More sharing options...
cipx2 Posted June 22, 2009 Share Posted June 22, 2009 Foggy is on his lunch break ... It should be FTC5072 for 300tdi R380 up to gearbox serial # 56A0669086K (FTC5202 after that). That is if your Defender is still on the factory brake pipes/fittings and it's not one of those vehicles with mixed 200/300 parts (although I think there are only late 200 series with 300 series parts, not vice versa). Which part# is the one you got and doesn't fit? Quote Link to comment Share on other sites More sharing options...
foggy3061 Posted June 22, 2009 Share Posted June 22, 2009 hi there Foggy,Any idea as to the slave cylinder? cheers Neil Oops! Sorry, for some reason i was thinking master! Slave should be FTC5072 on gearboxes upto 56A 0669086K: FTC5072 and FTC5202 on gearboxes from 56A 0669087K: FTC5202 Provided your gearbox is the original that maybe of some help! Quote Link to comment Share on other sites More sharing options...
foggy3061 Posted June 22, 2009 Share Posted June 22, 2009 Foggy is on his lunch break ... Certainly was! Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted June 22, 2009 Share Posted June 22, 2009 THIS forum is useful for part no. requests Quote Link to comment Share on other sites More sharing options...
pist0nbr0ke Posted June 22, 2009 Author Share Posted June 22, 2009 Cheers guys, just the ticket!!! Neil Quote Link to comment Share on other sites More sharing options...
