skydog Posted June 28, 2009 Share Posted June 28, 2009 Will Disco 2 body fit Disco 1 frame? Microcat shows both frames have the same part number. Any experience in such replacement? Thank you Quote Link to comment Share on other sites More sharing options...
BogMonster Posted June 29, 2009 Share Posted June 29, 2009 I have my doubts - the D2 body is quite a bit longer than the D1 (extra length in rear loadspace) By frame I assume youj mean chassis - I wouldn't have thought they were the same. The suspension layout is quite different and while I would have to check under mine I am 90 something percent sure it isn't the same where the suspension picks up onto the chassis. Quote Link to comment Share on other sites More sharing options...
cipx2 Posted June 29, 2009 Share Posted June 29, 2009 ........Microcat shows both frames have the same part number. ..... Please name at least ONE chassis part #, common to both D1 and D2. Here are the relevant part #s for D1s and D2s, respectively: Quote Link to comment Share on other sites More sharing options...
yogibear47.lee Posted June 29, 2009 Share Posted June 29, 2009 are you thinking 200 tdi body and 300tdi bodies, if you are i think they are the same Quote Link to comment Share on other sites More sharing options...
