green90 Posted June 30, 2009 Share Posted June 30, 2009 At the weekend I replaced the fuel pump on my td5 and now it refuses to start. I have run the purge sytem several times and still no joy. It doesn't attempt to fire at all, just turns over. Any help/advice would be greatly appreciated. Quote Link to comment Share on other sites More sharing options...
cieranc Posted June 30, 2009 Share Posted June 30, 2009 Fuel cut-off switch located in the engine room, central on the bulkhead. A square black thing with a rubber button on top. Press said button in! ............. maybe Quote Link to comment Share on other sites More sharing options...
landy andy. Posted June 30, 2009 Share Posted June 30, 2009 Can you hear the pump? Andy Quote Link to comment Share on other sites More sharing options...
green90 Posted June 30, 2009 Author Share Posted June 30, 2009 Yep, can hear the pump running, ok, no excessive noises. Have tried the cut off relay. Quote Link to comment Share on other sites More sharing options...
crwoody Posted July 1, 2009 Share Posted July 1, 2009 Could be an immobiliser problem? Quote Link to comment Share on other sites More sharing options...
green90 Posted July 6, 2009 Author Share Posted July 6, 2009 Thanks for the advice, woooohoooo it works must have just been an air lock, after repeating the purge/ turn over cycle until I was loosing the will to live, it decided to start. Quote Link to comment Share on other sites More sharing options...
