farmerboy_y2k Posted July 6, 2009 Share Posted July 6, 2009 My 85 rrc runs fairly well ticking over about 800rpm when the choke is first pushed in how ever as it gets up to temp (needle in middle of guage) the tickover rises to 1000-1100rpm. On sat when stuck in traffic and she got a bit warm (radiator on todo list) needle 2/3rds up the guage the tickover slowly rose to 1800-2000rpm! Also when its ticking over fast and turned off it tends to run on for a couple of seconds, is this related? Is it normal for tickover to rise with engine temp? Is it easy to adjust/fix? This is my first V8 I'm generally a diesel boy, but couldn't resist the noise. Martin Quote Link to comment Share on other sites More sharing options...
Coastcard Posted July 7, 2009 Share Posted July 7, 2009 One thought is to look at the distributor /timing and the advance mechanism within, which sounds like it might be sticky (the heat may be loosening it off a bit). Advance in revs and running on could be to do with this. Quote Link to comment Share on other sites More sharing options...
SteveRK Posted July 7, 2009 Share Posted July 7, 2009 I would also check for air leaks as well on the inlet manifold/carb junctions and also the engine breather pipes/vacuum advance piping/brake servo connection etc. Quote Link to comment Share on other sites More sharing options...
