daveysdisco Posted July 15, 2009 Share Posted July 15, 2009 need to replace my abs wheel sensor hub end is fine but where does the other end go to as i have traced it to the loom then stuck . its the nearside front which is the problem. any one help? Quote Link to comment Share on other sites More sharing options...
BogMonster Posted July 15, 2009 Share Posted July 15, 2009 On early vehicles it goes right up to the ECU, so have fun Later ones have a plug inside the wing, like they should have had all along. Quote Link to comment Share on other sites More sharing options...
martinhollings Posted July 15, 2009 Share Posted July 15, 2009 my 1999 t plate has plugs in the wing but some replacement abs sensers go all the way back to the abs ECU that is behind the box glove box Quote Link to comment Share on other sites More sharing options...
QTdarren Posted July 15, 2009 Share Posted July 15, 2009 hi mate , some go all way to ecu, some on the wings, there was a bulliten, to replace the hub and sensor,in one, as minor metal fillings in the hub was causing the abs light to come on , you prolly end up changing the lot ,tbh( or words to that effect). Quote Link to comment Share on other sites More sharing options...
