ThreeSheds Posted July 16, 2009 Share Posted July 16, 2009 The hub dampers on my 1990 RRC are held on by two countersunk screws which (according to several sources, including 'requests for parts numbers') are FTC3455. I have ordered and had delivered four of these screws which turn out to be much smaller than the ones fitted. So - do these look right? I am thinking that it is 'unusual' to countersink the holes so that they break through the sides of the damper and I am wondering if someone has fitted oversized screws at some stage? Cheers! Quote Link to comment Share on other sites More sharing options...
SteveRK Posted July 16, 2009 Share Posted July 16, 2009 Just had a look at my dampers and the csk head screws on mine fit within the csk machined dampers (recessed by about 1-2mm below the face)so if mine are correct then someone has fitted oversize screws to yours. I think mine are also standard pozi-drive heads as well although its difficult to see with the splash shield in place By the way - think you could do with some new seals on the hubs I did mine recently (cheated and cut them at the top so no need to dismantle everything and its lovely and dry under there now Quote Link to comment Share on other sites More sharing options...
ThreeSheds Posted July 17, 2009 Author Share Posted July 17, 2009 Just had a look at my dampers and the csk head screws on mine fit within the csk machined dampers (recessed by about 1-2mm below the face)so if mine are correct then someone has fitted oversize screws to yours. Thanks for that - I checked with a dealer and he said that the FTC3455 was for my model year but with ABS, and that mine (1990 non-ABS) should use FTC1623, so I have some of those on the way now.. Worst case is that they are the same but without the threadlock (over the phone I couldn't establish the difference), but I will report back when I see them. By the way - think you could do with some new seals on the hubs Yes - seals and seal retainers are in garage waiting for me to fit them.. Quote Link to comment Share on other sites More sharing options...
