bmc054 Posted July 21, 2009 Share Posted July 21, 2009 Hi I have a defender with Discovery running gear. I want to buy a swivel kit to refurb the front axle but there are many combinations,I have wire brushed the axles in search of numbers but to no avail Is there any way of identifying the axles visually?There is a large disc type "thing" attatched to the underneath/side of the diff. Thanks for any Help Quote Link to comment Share on other sites More sharing options...
Phil Hancock Posted July 21, 2009 Share Posted July 21, 2009 Thats a vibration damper as fitted on diesel D1/RRC. Quote Link to comment Share on other sites More sharing options...
western Posted July 21, 2009 Share Posted July 21, 2009 axle number is on later vehicles made up of letter/number shaped dot punch marks, wire brush/damp rag should make it visiblt, look above the horizontal weld line on the front of the axle tubes. Quote Link to comment Share on other sites More sharing options...
bmc054 Posted July 22, 2009 Author Share Posted July 22, 2009 axle number is on later vehicles made up of letter/number shaped dot punch marks, wire brush/damp rag should make it visiblt, look above the horizontal weld line on the front of the axle tubes. Thanks again for your help! As far as i can see the axle number is 34L 47907 C Could anybody tell me which vin numbers this would equate to . Thanks Again Bob (eng number is 12L11704A I presume this is from the same donor) Quote Link to comment Share on other sites More sharing options...
Matt Neale Posted July 22, 2009 Share Posted July 22, 2009 Thanks again for your help!As far as i can see the axle number is 34L 47907 C Could anybody tell me which vin numbers this would equate to . Thanks Again Bob (eng number is 12L11704A I presume this is from the same donor) Prefix / Suffix decodes as below. 34L C = F.AXLE DIESEL RHS NON ABS NON VENTED DISCOVERY Can't say what VIN range it would relate to though, sorry. Matt Quote Link to comment Share on other sites More sharing options...
bmc054 Posted July 23, 2009 Author Share Posted July 23, 2009 Prefix / Suffix decodes as below. 34L C = F.AXLE DIESEL RHS NON ABS NON VENTED DISCOVERY Can't say what VIN range it would relate to though, sorry. Matt Thanks for your help. Quote Link to comment Share on other sites More sharing options...
