hattymender Posted July 22, 2009 Share Posted July 22, 2009 Just spent a happy evening sorting out my rear wiper (duff connector). In a rash moment I opened the fuse panel cover (I hate wiggly amp electric stuff). Fuses all clearly labeled. Fine. And then there's four identical looking relays, and a couple more lurking around the back of the panel. No clues offered. I checked the manual. Nothing. Parts catalogue. Next to nothing. Does anybody have a 'map' of which is which for a 1980's 110? Quote Link to comment Share on other sites More sharing options...
western Posted July 22, 2009 Share Posted July 22, 2009 you should be able to ident them from the wire colour codes/wiring diagram start relay brake check indicator/hazard relay air con relays [if air con fitted] fuel pump isolation relay [not required for diesel vehicles, but fitted to prevent incorrect fit of other relays] Quote Link to comment Share on other sites More sharing options...
