Bob RRC Posted July 23, 2009 Share Posted July 23, 2009 urgent question - please advise me front diff for D2 (2000 MY) is the same as in D1 (from 94 MY) or P38 or its unique ???? my is going to die and i want to replace with used one, but from what car: D1 or P38 ???? Quote Link to comment Share on other sites More sharing options...
BogMonster Posted July 23, 2009 Share Posted July 23, 2009 Yes to a Discovery 1, not sure about p38. Any 24 spline diff will fit so also consider front or rear diffs out of any 300Tdi age 90, or the front diff out of a similar age 110. Should be tonnes of them about. Quote Link to comment Share on other sites More sharing options...
Off Road Toad Posted July 23, 2009 Share Posted July 23, 2009 It should be a long nose diff ie the same as D 1. A quick look underneath will tell you. Later D 2's have the short nose P38 type Diff. long nose sticks out approx 200mm from axle casing and short nose sticks out approx 160mm, ratio's are the same but they have different bolt patterns so aren't interchangeable. Steve Quote Link to comment Share on other sites More sharing options...
Bob RRC Posted July 23, 2009 Author Share Posted July 23, 2009 It should be a long nose diff ie the same as D 1. A quick look underneath will tell you. Later D 2's have the short nose P38 type Diff. long nose sticks out approx 200mm from axle casing and short nose sticks out approx 160mm, ratio's are the same but they have different bolt patterns so aren't interchangeable. Steve so i take complete diff from D1 and it will fit D2 without any problems ?????? (if i have long nose diff) Quote Link to comment Share on other sites More sharing options...
nicks90 Posted July 24, 2009 Share Posted July 24, 2009 yes. Quote Link to comment Share on other sites More sharing options...
cipx2 Posted July 25, 2009 Share Posted July 25, 2009 I've never heard of long/short nose diffs on D2. AFAIK and EPC tells, there's only one type of diffs throughout the series. Assuming long/short nose would mean a different overall length, this would imply a different propshaft length. Again, there's only one prop version front/rear (depending on engine and transmission) throughout the series. Quote Link to comment Share on other sites More sharing options...
BogMonster Posted July 25, 2009 Share Posted July 25, 2009 I'd never heard of one either but assumed I'd missed something. All the Discovery 2s I've ever seen had the standard diff but I can't say I have specifically looked under an 04 to check... Quote Link to comment Share on other sites More sharing options...
