tommi Posted July 26, 2009 Share Posted July 26, 2009 I have used the search function but couldn't find anything. I've got a problem on my 1992 defender regarding the front wipers. The normal and intermittent settings work fine, but when i switch them onto the fast setting, they just stop (they do return to their correct position). They were working fine until a couple of days ago, and I haven't messed with anything behind the dash recently . Any ideas what the problem could be? Thanks in advance. Quote Link to comment Share on other sites More sharing options...
western Posted July 26, 2009 Share Posted July 26, 2009 was the screen dry ? as that can put to much load on the motor & make it stop, otherwise it could be a sticky motor Quote Link to comment Share on other sites More sharing options...
tommi Posted July 26, 2009 Author Share Posted July 26, 2009 was the screen dry ? as that can put to much load on the motor & make it stop, otherwise it could be a sticky motor No the screen wasnt dry. I only realised when I tried to switch them to fast during a torrential downpoor. What do you mean by sticky motor? Quote Link to comment Share on other sites More sharing options...
western Posted July 27, 2009 Share Posted July 27, 2009 sometimes if the wiper arm loading is to great [a dry screen] the motor will be powered but stop running [stick] until some water [sceenwash] is fired at the screen/blades then it will run again. suggest unpluging the motor & do a check at the plug while you operate the wiper switch to it's various positions, might be the fast speed wire on the switch has a poor connection. Quote Link to comment Share on other sites More sharing options...
