Gavin Hatton Posted July 27, 2009 Share Posted July 27, 2009 Hey All, My recently acquired 1998 110 300Tdi Hard Top's heater blower stop working the other day. I've check the fuse (fuse 5) and that tests OK. In removing the fuse holder to further check the wiring I found these three plugs (Blue, Yellow and clear), each with nothing attached to them, anyone any ideas as to what they mite be for? Also anyone any ideas as to why my blower has stopped / suggestions of other things to check? Thanks in advanced, Gavin Quote Link to comment Share on other sites More sharing options...
The Badger Posted July 27, 2009 Share Posted July 27, 2009 The clear on could be for a fag lighter? It there are three wires on it, one in earth, on is side light, one wil be power when ignition is on. the others are proberally for other dash kit you can install later, like heated screen etc Quote Link to comment Share on other sites More sharing options...
Gavin Hatton Posted July 27, 2009 Author Share Posted July 27, 2009 I'll get the tester out on the clear one, not sure if it'll be fag light outlet as there's on in the centre dash already. Quote Link to comment Share on other sites More sharing options...
western Posted July 27, 2009 Share Posted July 27, 2009 possibly for air condition when fited. Quote Link to comment Share on other sites More sharing options...
Gavin Hatton Posted July 28, 2009 Author Share Posted July 28, 2009 Problem sorted. One of the connectors to resistor on the heater box was loose and weak. Also when looking I found the bung on the lower part of the air intake to be filled with crud and the fan was sucking at the water that had built up. Anyway all in all, problem found, fixed and sorted! Thanks for the info on the plugs behind the fuse box. Quote Link to comment Share on other sites More sharing options...
western Posted July 28, 2009 Share Posted July 28, 2009 good day for cheap repairs Quote Link to comment Share on other sites More sharing options...
