JJ7893 Posted July 30, 2009 Share Posted July 30, 2009 Could anyone give me the part numbers for the seals in the rear axle? I'm after the inner and outer seals with a diff seal too please. It's a 24 spindle 1994 Discovery ES. I'm changing the Axle casing and I am buying the axle brand new so I dont have this problem again and so I can keep it in working order. Is there anything else I would be needing when changing over the casing? also any tips that could help me? Thank you .....JJ Quote Link to comment Share on other sites More sharing options...
western Posted July 31, 2009 Share Posted July 31, 2009 Hopefully these will help --- rear axle seals/gaskets from VIN JA032851 gasket drive member x 2 -- 571752 seal hub inner x 2 ---FTC4784 diff to axle gasket x 1 -- 7316 diff pinion to diff housing seal x 1 -- FTC5258 [up to vin VA558898] or FRC8220 Quote Link to comment Share on other sites More sharing options...
JJ7893 Posted July 31, 2009 Author Share Posted July 31, 2009 Thank you Western, I get them ordered tomorrow morning. .........JJ Quote Link to comment Share on other sites More sharing options...
stewy1984 Posted July 31, 2009 Share Posted July 31, 2009 Theres a gasket between the stub axle and axle casing aswell. not sure on the part number. I personally wouldnt use the gaskets (stub, drive member and diff) and just use a good sealant instead. RTV Quote Link to comment Share on other sites More sharing options...
western Posted July 31, 2009 Share Posted July 31, 2009 Thank you Western, I get them ordered tomorrow morning. .........JJ happy to help, sorry for the 1 day delay in replying, but I had to find the number first. Quote Link to comment Share on other sites More sharing options...
