Alternator problems V8Efi
calvin
The battery charging light has just come on and when I checked at the battery with the meter it wasnt charging , so it looks like the alternator. All the connections etc are sound so it looks as if it needs to come off for a look.
the saga continues, I got a replacement alternator 2nd hand but now I have fitted it the battery light is staying on despite the fact that there is plenty of volts (14.4) coming out of the alternator. A bit weird. I have decided to live with it for now but keep checking the output manually regularly and fork out for a new alternator if this one fails.
Any ideas why the charging light is still on?
Or possibly a broken wire in the warning lamp circuit at the alternator end - whip the plug off and see if there is 12v ish on the thin wire (brown and black on mine) with the ignition on. If not, the wire is broken.
