john242 Posted August 1, 2009 Share Posted August 1, 2009 nearly mot time,while replacing the rear brake lines found that the lhr inner wheel arch was well rotten so hoping somebody can recomend a good supplier I'm cack handed at fabrication. Quote Link to comment Share on other sites More sharing options...
sheltie50 Posted August 1, 2009 Share Posted August 1, 2009 Just dropped in from the other side ;-} wonder if this could be the same or close enough to the Range Rover Classic, I think they might be but please check for yourself, if so they are readily available from aftermarket suppliers, get a copy of LRO or search the web, its all out there. If you have found corrosion have you checked around the rest, rear xmember, rear floor etc, I have recently done a repair which started out as a rear floor but ended up with major fab work. Quote Link to comment Share on other sites More sharing options...
